attowatt
OK,
I got bored and was going to use these switches (digikey EG1872-ND) for another mod( I still am), but noticed that they may work for a dorcy aaa. Pulled apart the tailcap and was trying to figure out how to best secure the switch inside. Well it so happens the switch is a very snug fit inside the main body. Not only that, but the center contacts on this switch (DPDT), are the N.O pin and these are what make contact with (-) battery side(see pics). The switch is rated at 30vdc @.1A so at ~2 volts and using both sides of the switch...well you get the picture, it will handle the current; which is .3A on a fresh battery.
Bend the (C) and (N.C.) pins outward as seen in photo. This is what will make contact with main body tube. I soldered the (C)Common pin to the (N.C) Normally Closed pin JUST for reinforcements. Bend inwards, the 2 center pins and solder; these are the 2 (N.O) pins on the dpdt switch. Normally this is not the case when using a DPDT type switch; I am OK with this as I was just looking for a click on/ click off feature for dorcy. I had to snip the tip of the swich(blue) so it would work with the yellow boot.
The yellow rubber boot was robbed from a garrity incan 2 aa light from walmart. I am sure other substitutes are available
Oh yeah... my tailstand caps still work after the mod. Those are available here:
http://candlepowerforums.com/vb/showthread.php?t=89452
$1.22 DPDT Switch here:
http://dkc3.digikey.com/PDF/T053/1323.pdf
