I've got a popup camper that currently doesn't have reverse/backup lights. These would be really convenient/helpful when backing into campsites after dark. The simplest solution would be to get some cheapie automotive lights (ie fog lights) and mount them on the back bumper of the camper. These are usually 55 watts (~4 amps at 12V) each. One light and certainly two would not doubt require a relay instead of pulling power from the existing reverse light circuit on my car. Even downsizing to lower wattage bulbs would be pulling more current than I want to pull off that circuit.
So what would be a good LED solution? I don't need to light up the entire area behind the camper, mainly a few feet behind the rear corners and to the sides a bit. A couple Lux's maybe? Or maybe 1/2 dozen Nichia CS's? Then comes to how to mount them. A small diameter section of PVC could be mounted above the bumper to mount the LED's in. I could even mount an LED in each end cap for some side lighting. Painted black this would be nearly invisible.
On the electronics front, my first thought is to build a voltage regulator and drive them at 3.5-4.5 volts. It's possible I would also use these as area lighting for longer periods while camping so I'd choose a voltage that doesn't drive them too hard.
I'd love to hear what input comes from this group.
Thanks,
Matt
Thanks,
Matt
