2xPilas a clickie tailcap and a Lux V. Dimmable?
Lunal_Tic
The Wilds of Tokyo
I'm thinking of a project to convert a 2x Pila light with a clickie tailcap to a dimmable Lux V BUT I'd like it to be regulated so I don't cook something.
Is this possible? Can I combine something like a uPIC and a Downboy to get the multi levels? Can those programmable thingys work with clickies? And how many inches to the moon? (sorry I got carried away):grin2:
Any insight will be appreciated.
-LT
Lunal_Tic
The Wilds of Tokyo
Come on guys. Nothing on this??? There's got to be something out there that will work.
Help a nut case out will ya? :crazy:
TIA,
-LT
gadget_lover
Near Silicon Valley (too near)
TIA,
-LT
OK, a pair of pila's gives you 7.5 volts, right? That's close to correct, So a uPIC that is essentially a PWM controller will control the duty cycle so that, on average, the LED will have the right voltage. A simple LDO could handle the peak volatges to keep it happy.
Since the downboy is a current regulator, you can't put the Upic between the downboy and the LED. If you put it between the downboy and the battery, you will be supplying a pulsating dc to the downboy which does not sound like a good idea.
Daniel
goldserve
Toronto, Canada
It's not impossible but what you are looking for, I thin georges80 has already. Check out his site for some converter boards he may have.
As a side note, if anyone has some experience in designing buck/boost regulators and would like to hook up with me for the uPIC design of it, please contact me. Thanks.
mobile1
Switzerland&San Francisco
go to taskled.com, get an nflex, 4 rechargeable 123's (total 14-16V), a momentary pushbutton, a LuxV, assemble it all and you are ready to roll.
Lunal_Tic
The Wilds of Tokyo
Thanks mobile1 but this is strictly a 2xPila affair. I need another battery type like I need another hole in my head.
-LT
