bwaites
Since the U2 is regulated, is it brighter on rechargeables or 123's? Is there any difference?
Bill
Bill
wasBlinded said:Just about as soon as the battery voltage exceeds the Vf of the LuxV (usually a bit above 7 volts), the U2 is no longer regulating. You can't even dial down the brightness. Which means that two R123 cells in a U2 will seriously overdrive the LED.
bwaites said:Cy,
That's quite the combo of annodization on the U2!!
Mine is perfectly even black, is mine weird or yours?
Bill
