Re: please help me set up wirelsss
Hi Raggie -
Setting up a wireless link is not that much different than setting up a wired network. If you want to connect directly from one computer to another (without going through a wireless router, which is referred to as an "ad hoc" setup), then you can think of it as being like connecting two computers directly using a crossover cable. Here is a reasonably good
ad hoc guide
There are a number of good wireless setup guides available, although most are geared for using a wireless router (an "infrastructure" setup, similar to using an ethernet switch in a wired network), such as
here
Just turn off all the security settings (WEP, WPA), and see if you can make the wireless link. Once that is up and running, you can start playing with the security features.
Good luck!
John
