sleidig1 said:
Which of the following is brighter/more throw?
Arc-AAA Premium or Photon freedom x2
I found a listing showing that the Arc-AAA Premium is rated as 5.5 lumen with 5 hours to 50% brightness.
But I can't find a lumen rating for the Photon freedom x2
Thanks in advance.
I only have the Photon Freedon x2 at the moment (my ARC-P is in the mail), so I can't do a direct compare.
Using the numbers at flashlightreviews.com it would seem that if the x2 really is twice as bright as the original then it will slightly out throw the ARC-P, with slightly less overall output. (But I tend not to trust manufacturer's claims, and suspect that it's more like 1.5 times as bright...) And that's on fresh batteries...
But you are comparing two very different lights, even though they both qualify as "keychain" lights.
The ARC will last forever, can use cheap batteries, is waterproof, and will not turn on accidentally in your pocket.
The Photon is plastic / not waterproof, uses pricier batteries,
will turn on accidentally in your pocket, and has some really cool special features like dimming and flashing.
So, "which is brighter" might not be the best first question to ask. First you should ask yourself what you are going to use the light for, and how are you going to carry it.
I really like my Photon Freedom x2, but I don't EDC it. It does cost less than the ARC, but the batteries cost more and won't last as long, so "feeding" costs will be higher.
