I just bought a RR 2AAA at Target yesterday after reading all the glowing reviews about it here. But a question has come up:
I was under the impression that you have to hold the button down and rotate the cap to keep it turned on. Here's how mine works: If you tighten the cap all the way after installing the batteries, it comes on. Then you have to loosen it til the light goes off. At that point, you can push lightly on the cap OR the button to make the light come on. If you loosen it a little more, then only the button will make it come on.
I like to loosen it beyond that to keep it from coming on at all in my pocket, then tighten it a bit as I'm about to use it. Kind of a pain though.
Anyway, is the way I described mine the way it's supposed to work, or is mine a defect?
