MJLED in a Minimag:
I ran a informal test with a MJLED in a 2-AA alkline and 2-C alkline.
I ran it continiously at night by turning it on when I went to bed and checking it when I woke up.
This is from MEMORY and while might not be exact gives you a idea.
After 10 hours (1 - night) the AA was a little dimmer but still going strong.
After 20 hours about the same
After 30 hours the AA was starting to get dim but still aboout like a normal 1 LED light (20mA or so)
After 40 hours it would still project across the dark room but was reaching the end of it's useful life. Something like 5mA. Would still be good enough to use in a power outtage if I had to.
Voltage on the cells was down to about 1.35-1.38V. Still plenty of power in them to run something like the Nite-Ize upgrade or a while.
Of course the 2-C version was still almost as bright as fresh batteries.
wwglen
