gb6491
Sears has this light on sale for $12.99 until 10/29/05.
http://www.sears.com/sr/javasr/prod...Yes&vertical=TOOL&pid=03493673000&tab=des#tab
Some spec from Sears:
General Features:
Bulb Protection: Polycarbonate
Bulb Wattage: 1 watt
Bulb Type: LED
Flashlight Continuous Use Time: 17 hr.
Flashlight Housing Material: Stainless Steel
Water Tight: Yes
Controls, On/Off Type: Push button
Dimensions:
Diameter 1-3/4 in. Flashlight Length: 6-1/2 in.
Batteries:
Number Required 3
Number Included 3
Cell Type: Alkaline AAA
I bought this light because I wanted the PR base LED for my Mag 3c.
The way it turns out I'll probably go back and get another one to do that with.
This is a nice little flashlight. The LED emits in a very white color and the smooth reflector (fixed focus) does a nice job producing a tight hot spot with no artifacts.
Side spill is similar to a Mag on tight focus and comparable to a Fenix L1P except the hotspot is tighter and the spill is not as bright.
The 3AAA is very light and fits well in a coat pocket. The lens, reflector and bezel are all one plastic piece. There is a metal ring where the bulb holder screws in. The bezel is rubber armoured as is the rear end. There is also a flat bar on the bezel to prevent rolling. The batteries load easily into a carrier that is easy to load into the light. The carrier loads from the bezel end. The push button switch is a little firm to operate but very positive. It is reverse clickie type.
This light outthrows the Fenix L1P v2.5 and Nuwi Q3 that I have, but the spot is narrow. I pulled the LED after about 10 minutes use; it was warm edging towards hot (you can hold it).
Speaking of the LED, it works well in the Mag 3C. It will focus down quite tight and competes well with a LedBeam 3watt 3c.
There are some photos and beam shots here: http://gbrannon.bizhat.com/sears.htm
The wall in the beam shots is 15 strides away.
Please excuse my poor photography skills (I also have a low end digital camera I have to trick into taking beam shots by covering the light sensor).
Regards,
Greg
General Features:
Bulb Type: LED
Water Tight: Yes
Dimensions:
Batteries:
Number Required 3
Number Included 3
Regards,
Greg
