pretty much have to just ease the reflector out and let the legs bend an/or break. just be careful to keep the shiny side pristine.
I had called terralux and got the Ok to put the full li ion voltage thru there mirco, just heat, no real damage to the module. I resistored it down once but since the interaction between the SMD and the reflector makes for poor throw
I went back to having full juice, i just don't use it very long, much my other 1xAAA type KC light's.
I recommend drilling rather then sanding the reflector too, this will give you a little more material left, and give the switch more to bite on then sanded down.
There are some tricks i have been doing to soli reflectors since i started moding them last yr. the last 2mm is flat on it, and if your very careful it can be removed from the main portion and fused with a stock (but drilled) one
for a uber flood and power. (I 'm given' all my soli secrets away so don't any of you's go makin' and sellin' these on the custom BST! just kiddin
One more thing, the reason the soli is giving out so much flood vs hotspot is the nature of the SMD/reflector interaction. the micro throws like hell in a 2xAAA mag because of the strong parbolic curve were the SMD's very low mounting starts on the terralux made reflector. I wish these could be ordered in a regular 5mm or even lux,
Because when placed in the reflectors hot spot, the 5mm do throw!
I got two soli conversions with 35K 5's "Resistored" that make a new ARC v4 look like stock soli.
Anyway my point being, I don't think much can be done on the soli reflector for throw, at 3.7V maybe someone with better skills can suss out the current/voltage requirements of the micro and find a replacement LED that would spank bigtime. I truly love the terralux modules and the micro for a soli mod,, just feel it could use a better LED. VDG
