spoonrobot
- Joined
- Aug 2, 2005
- Messages
- 396
Just thought I'd share a little tip for anyone who actually likes the new Inova Radiant AA. I found this light to fit my needs perfectly except for the fact that there was no way to prevent the light from inadvertantly turning on when carried without use of a sheath. I figured out that if you unscrew the tailcap enough it will lock out the light but at that point it is very loose and is very easy to lose. The solution to this is to wrap the threads with some cheap teflon tape and create enough tension that it is still easy enough to turn the tailcap but not so easy that the tailcap is in danger of falling off.
