wquiles
EDIT: I finally was able to measure the voltage at the LED's with the lamp ON and with 2 rechargable CR123 cells - see post #11 bellow. Given that the voltage at the LED's is just the voltage under load, it is indeed too high for the factory value of 33 ohms. Those of you who want to use their A2's with rechargables should either use a larger resistor for each LED or exchange these resistors with the MJLED's (or equivalent high current LED's) to prevent early death of your factory LED's. Since I made my LED swap and resistor change to 110 ohms, I now have at least 20 cycles on AW's MP700 rechargables, and this setup works great!.
End EDIT
Thanks to AutoraLite's awesome post on how to modify/change the LED's in the A2 (link ... ) I decided to do my own as well as my particular A2 had the worst case of angry blue LED's I have ever seen :sick2:
I was also particularly intriged about the current going into the LED's since AuroraLite had reported the A2's LED module using 33 ohms in series with each LED and having all 3 LED's wired in parallel. I of course was able to verify that in my unit as well. So far so good.
Since I do want to use my A2 with rechargables, I did my measurements with 3 power sources:
1) spent CR123 cells. Not even enough juice to ignite the A2's lamp, but enough to drive the LED's. Vnoload=5.57v
2) new SF CR123 cells. Vnoload=6.14v
3) fully charged rechargable CR123 cells (AW's MP700 cells, to be specific). Vnoload=8.28v
So using the stock resistor values:
1) spent CR123 cells = 80mA total - about 26mA to each LED
2) SF new CR123 cells = 150mA total - about 50mA to each LED (no calculator needed here )
3) charged rechargables = 320mA total - about 106mA to each LED !!!
So assuming normal 5mm LED's, even with spent cells, these LED's are being driven past the nominal value of 20mA. With new cells, they are VERY overdriven, and with rechargables, they are close to self-detonation
Why would SF allow these poor 5mm LED's to be driven at 50mA's is beyond me, as this can't be good for longevity, but for those few that are starting to use the rechargable cells in the A2, be aware of what you are doing to these poor LED's :sweat:
So needless to say, when I decided to replace my LED's I also knew I would be "fixing" this problem. Using several discrete resistors and battery sources:
I took many measurements as you can see here (assuming you can read my chicken scratches) and lack of any order (these notes do make sense to me somehow):
So I basically ended up with a 110 Ohm surface mount resistor with new 35K's from KevinL (great tint!) that would give me the following:
1) spent CR123 cells = 42 mA total - about 14mA to each LED
2) SF new CR123 cells = 68mA total - about 22mA to each LED
3) charged rechargables = 120mA total - about 40mA to each LED - much better
So my humble conclusion is that even with normal CR123 primaries these OEM 5mm LED's are being overdriven and if using rechargables then I don't see the LED's lasting much at all, or at the very minimum they will degrade very quickly.
Please measure your own A2 and let me know what you find so that we can compare notes and help others as well
Will
End EDIT
Will
