OK, be gentle... I am completely new at this. I was looking through some of my old stuff and found an old Everlast headlamp. Just a cheap one, but I remember it was always really bright. I used it for watching wildlife after dark.
Well, I saw what the lantern batteries now cost, and I have a lot of those 9.6v rechargeable packs that go in my kids' remote controlled toys and figured that those would be just the thing... I could use the lamp and rotate the batteries as needed, keeping the cost down. I took the end off of one of the chargers, adapted the headlamp wire to use the end, and 'voila', the battery snapped on.
I shined it for a few seconds in my basement and was impressed with the light output; I then went outside to see how far the beam would throw, and when I turned it on it flashed for a second then went dark. I took the bulb out, and I don't see where it is burned out but I assume that's what happened. It says on it "Norelco PR13, IE4".
So, I was wondering, is there a particular type of bulb I should get to replace the bulb to make it work? I need strong light output and pretty good battery life for this headlamp; several hours per battery.
Any ideas on how I can rig this into my ultimate headlamp?
