Nikola -
Regarding 18650s. In light of the sometimes odd behavior of protected cells on incans that's been reported on CPF, having to "prime" the bulb with two ore three flashes before the protection circuit enables current to flow, for the $6 mentioned, are you referring to the unprotected cells from
THIS THREAD? If so, do you have any precautionary wisdom on how to best manage unprotected cells during charging and usage?
According to Energizer's
DATA SHEET for their latest and greatest NiMH AAA of 850mAh, the discharge curve for the illustrated draws of 850ma (1C) and 425mH (.5C), voltage drops to 1.2V at about 35 minutes and 70 minutes respectively and drops to 1.0V at 1 hour and 2 hours respectively. So I'd expect that the discharge curve for 650mA would fall almost evenly between them. I'd be interested to know if you have any experience to the contrary.
When you say "tailcap ground out", do you mean to scrape enough anodizing off so that the battery and/or the aluminum foil make contact to complete the circuit or to shed a millimeter or two off the cap so that there is extra room for the 18650 batts....or do you mean electrical ground?
73
dim
