NewBie
*Retired*
I don't remember posting this before.
Did you know the CREE LED can take 1500 times the force of gravity in all concentrated in 0.0003 seconds, and the test involves doing it along six axis and five hits each?
Did you know the CREE LED can pass the salt spray corrosion test?
Did you know the CREE LED can be thermally shocked and pass, getting hit with -40 to +125 degrees Celcius, with a transfer time of less than 20 seconds, 200 times?
Did you know that they test samples out of every lot to assure they can pass RTOL (room temp testing), HTOL(high temp testing), and WHTOL(wet high temp testing)?
There are lots of more facts, found here:
http://www.cree.com/products/pdf/XLamp_Reliability.pdf
