TorchMan said:
All this talk about U bins has me green with envy. :green: I've a Raw coming, but it's a T bin. Did you have to be one of the lucky few at the start? I know they are rare.
Yes, I've got one of the U-binned Orb RAWs, direct from 4sevens with his two-stage mod, which preceeded the one that Rob sold by a few months. It's a GREAT little light - bright, but it doesn't get as much use as it ought to, due to the fact that I've managed to somehow kill two RCR2s even when the light was left on a desk, and because it doesn't have O-rings, which makes it less than optimal for use in winter or merely wet weather.
It's definitely a beauty, and bright enough to stand up to any of my other higher-powered LuxIII lights, due to the sheer output of the U-binned LuxIII.
Spidey82 said:
y is the u bin so rare???
2 stage is T bins?
if i wait, will the u bin be avaliable in furture?
U-binned LuxIII's are rare because Lumileds' production methods aren't perfect, and because few LEDs make it out of the factory with the ability to put out as high a flux as to rate the U-designation, and most of those are bought by manufacturers... which means that the chances of people like you or me getting them is extremely low. All current RAWs out there (not the 1-watts) use T-binned LuxIIIs, because that's all Rob can get at the moment.
Personally, I'd suggest getting a U-bin LuxIII yourself (you'll probably need a U--K or U--J binned LuxIII) and sending it to Rob to have it put into a RAW module, rather than waiting for him to get another batch.
Or just wait for the next-gen Luxeon K2's to come out... sometime in 2006.
