Thanks Al, it's great to hear and understand the story behind this little piece of history.
I am using it with the MN16 lamp, and while I'm aware that it's not an 'officially recommended' configuration, the beam is very tight especially compared to the MN16+KT combo, and I am very pleased with it. The hotspot is a little oval-ish, but it doesn't really bother me because the beam collimation is excellent. I would say that this is one of the tightest beams I've ever seen in a flashlight - eloquent tribute to Surefire's engineering.
My own experiences with building hotwire incandescents (the Roar of the Pelican projects in particular) have taught me that while I can easily pack more 'absolute' numbers of lumens, Surefire makes more efficient use of the photons. For example, my ROP Lithium Edition (2C Mag, 2x18650 lithium ion) and bulb combo puts out approx. 600 output lumens, but it is a wide flood. The ROP/LE and the SRTH+MN16 combo achieve the same spot brightness at the same distance, but one has to generate so many more lumens to do that because of the inefficient beam collimation of the metal Mag-replacement reflectors we use.
This was tested one night using the 'resolving power' test. Resolving power is a term in photographic circles referring to how much detail one can perceive, they normally use resolution charts to test the resolving power of lenses. Better lenses bring out more details in the subject.
I'm building my own variation of this test for flashlights. We are using the same pair of lenses (eyes, to be technically correct
) and varying the light. We tested a ROP/LE (600 lumens), KT1+MN60 (225 lumens), SRTH+MN16 (225 lumens). Choose a distant object, to the point where you can barely see the detail. If all lights bring out the same amount of detail as perceived by your eyes you need a more distant subject, so try again.
Once you decide on a point, aim the lights at the same point and test each of them. The light that enables you to see the most detail has the brightest spot. You can check beam collimation by looking at the side of the beam, works better if there's moisture in the air.
The KT1 lost the resolving power test by quite a fair margin, the ROP/LE and SRTH are equal to each other, but the ROP/LE has very poor beam collimation and the only reason why it can match the SRTH in the resolving power test is because of its 3X lumen output. Independent opinions from 4 different pairs of eyes (some with corrective optics, all of varying age) were consulted and the results tallied
The resolving power test is quite a useful one, because the more detail you can pick out at a given range, the easier it is to identify what you are looking at, which is generally what lights tend to be used for.
