adrianmariano
- Joined
- Oct 24, 2005
- Messages
- 112
I was looking for a light to use for emergency illumination when the power is out. I got a 20 LED lantern (from amondotech). But while I was waiting for it to arrive, I found the Ice Storm article at flashlightreviews (http://www.flashlightreviews.com/features/storm.htm ) and he doesn't mention lanterns but suggests pointing broad beam LED flashlights at the ceiling. So I tried using my Streamlight 4AA with 7 LEDs and we liked the illumination from that better than the illumination from the 20 LED lantern! I wouldn't want it a whole lot dimmer than the Streamlight. (And I don't know how old the batteries are. The streamlight dims pretty quickly as you use it.)
For a protracted outage, the Streamlight would need a lot of batteries. And while it will stand on its end it's precarious. The above mentioned article suggests the Lightwave 3000 and Lightwave 4000 which seem a little pricey and also don't stand on their ends. These are fairly old models. Is there something better out there?
I checked the review sites and found the Lumaray lights, which at least can stand on their ends. But $120? And you don't even get regulation and multiple light levels? It's down to 50% light after 6 hours which is the same as the (manufacturer claimed) runtime of the Streamlight 4AA. It seems that back when the Lightwaves and my Streamlight came out, the flashlight reviewers weren't doing their own light output plots. (The Lightwave is supposed to go for 600 hours! Hard to believe.)
So here's the question I pose. What flashlights out there meet all or most of the requirements on this list:
1. Produces enough light in a broad beam to illuminate a room by pointing up at the ceiling. I figured you need 7 LEDs for this taking my streamlight as a benchmark, but maybe fewer brighter LEDs would work as long as the beam isn't too narrow.
2. Is stable standing on its end so it can illuminate the ceiling.
3. Has a long run time (which presumably means big batteries, C's or D's)
4. Uses standard batteries.
Anything out there like this?
