ArmyTek
Results 1 to 12 of 12
Thread: Nuwai ALX352L FLuPIC TW0J 18650 mod
    Flashaholic* chimo's Avatar
    Sep 2004
    Ottawa, Canada
    Default Nuwai ALX352L FLuPIC TW0J 18650 mod
    I purchased a dead ALX352L some time ago with the intention of modding it. The original driver circuit had a couple of blown MOSFETs due to a shorted output.
    This host was a 5W, 2x CR123 but I have modified it to accept 18650 cells that were pulled from some laptop battery packs.
    I started by creating a board that aould have the positive and negative battery contacts. This board also contains a Q3 switch embedded to the correct height for button contact.
    Random Battery shot - note the extra height of the Protected R123!
    Note how good a fit the 18650 is for 2x CR123 replacement.
    The Tube was bored out to accept the 18650. Lots of wall thickness left.
    Beam Shot Low/Medium
    Side by side. Nuwai with MiniMag
    Paul
    Flashaholic* LumenHound's Avatar
    Apr 2005
    Toronto
    Default Re: Nuwai ALX352L FLuPIC TW0J 18650 mod
    Very nice!
    How warm does the body get after 10 minutes on the the FLuPIC's 20/20 high setting and how much current is it drawing?
    That reflector is about 34 mm wide, right?
    Sep 2004
    Ottawa, Canada
    Thanks Lumenhound.
    That thing has a ton of thermal mass so the body just gets slightly warm.
    I believe on High Mode (20/20) there is only one LDO regulator turned on and that limit's the output to about 550-600mA. The Luxeon is under-driven until the FLuPIC is switched to Max. On Max Brightness, both LDOs are turned on for 1.1-1.2Amps to the Luxeon.
    Between High and Max, my eyes do not see a great difference in output, but the light meter does.
    I like the reflector - it's partly OP'd and produces a nice beam. I don't have the light handy right now to measure it.
    Paul
    Dec 2004
    Toronto, Canada
    Very nice mod indeed! Now if we could get some runtime graphs...
    Sep 2004
    Ottawa, Canada
    Quote Originally Posted by goldserve
    That's kind of funny, I started one yesterday, but stopped it when I did not recall what level I had "High" set at.
    Paul
    Sep 2004
    Ottawa, Canada
    Here's a quick runtime from an 18650 pulled from an old laptop battery pack.
    The setting should be at level 20 (one LDO ~ 550-600mA). Just over 2.5hrs to 50%.
    On Max setting (both LDOs) the output is over 4000 Lux @ 1m!
    Lumenhound, the reflector is 32mm dia.
    Paul
    Dec 2004
    Toronto, Canada
    Very nice graph. What are you using to log the runtime? A few other questions:
    Are you using two 18650s in parallel or just one?
    Sep 2004
    Ottawa, Canada
    Thanks ,
    I use a ProteK 608 connected to my Meterman LM631 for graphing. I import the data and graph it in Excel.
    The runtime is with one 18650 - recovered from a laptop battery pack that was being discarded. There is no indication of mAh on the cell.
    Paul
    i need to do a new circuit to work with 18650 because needs more space?
    Sep 2004
    Ottawa, Canada
    Quote Originally Posted by marcos7007
    I'm sorry but I am not sure what you are asking. The 18650 is the same length as 2x CR123s so the circuit board position will not change. I changed circuit boards to the FLuPIC.
    because in alx352l go 17650 / 70 = 168S or 600S
    and not
    18650 = 168A or 600A
    did you make any mod to accept 600a instead 600s
    http://flashlightreviews.com/features/pila_table.htm
    Feb 2006
    Vancouver, BC, White North
    and not
    Well he bored out the body.
    The only physical difference b/w 18650 and 17650 is the 1 mm extra diameter. Both have the same length @ 65 mm.
