I just got a U2 sent to me. We tested about 30 of them in a bunch of lab tests we put them thru along with the 30 Gladius lights. This one must have been subjected to some of the more mild tests as we did some shock to destruction tests as well.
This U2 has an excellent beam quality with virtually no artifacts and no doughnut hole even at extremely close range (1/2" from the target area). I have seen a few that had definite doughnut holes at this close range.
Overall beam pattern is more diffused, but very, very nice.
When I shine U2 against the wall and incrementally bring down the light levels, there is a definite movement towards a yellow/green in color. In the grand scheme of things, I really don't think that matters much. The U2's lowest level is still way too bright for stealth work in my opinion. The instruction manual says the light will run 40 hours at the lowest level. As mentioned it is a 5W LED.
When I shine the Gladius against the wall and dim it down, the color spectrum does not seem to shift as much, staying a bit closer to the white/blue. The Gladius will run ten times longer, that is 400 hours at its lowest level. We would like to get it even lower in output, but the LED will begin to flicker if we drop power any lower. The Gladius has a 3W LED.
The Gladius has a much more intense and tighter hot spot at room distances, but not as clearly defined as the SF U2. I took both lights out into the dark woods behind my house.
Inside of 15 yards you are going to see more in terms of overall surface area with the U2 as it serves as a better flood focus. But the Gladius clearly out throws the U2 I have. I can shine the U2 and definitely walk right on top of it at distances exceeding 50 yards. So it is a question of preference at that point.
If you are looking for perfect beam quality it the sense of a perfectly round/defined hot spot, the Gladius is not the light for you. This is easily seen by shining both against the wall and merging the beams. A more crisp beam signature is something I think we could make some good improvements in down the road. I don't think it is critically important, but it just looks better that way, no doubt about it. Let me also point out there is no dark holes or gaps in a properly pre-focused Gladius.
The Gladius stands a bit taller than the U2, but is a bit sleeker on the front end.
The clickable switch on the U2 is perfect in terms of pressure. Not too easily activated.
I am going to keep the U2, not for fighting but for a variety of tasks that this type of light would be best suited for. I don't think SF ever intended this to be a purely fighting light as they have quite a stable already. Oh course that is purely speculative on my part. It takes 2 hands to adjust the levels of light. If I had it pre-set for a lower level and needed to retrieve it, and get in running at its highest level in a fight, it is simply time and one main weapon I do not want to give up.
However it is quite easy to take the light, quick twist of the adjustment collar in the counter-clockwise position and you know you at the lowest level.
The adjustment ring is smooth and the light has superb fit and finish, indicative of a SureFire.
I have a saying I always throw out there…"Half of going fast is lookin' fast…"
This SureFire looks great on all fronts.
My totally biased final assessment: :touche:
If you are looking for a highest quality administrative light that could also serve you well in a self-defense situation the SureFire U2 is no doubt a great choice. Simple, easy to operate.
If you are looking for good light for purely tactical applications, the Gladius is better choice based on the ability to go from stealth to full power Strobe or momentary in a flick of your finger. The user changeable programming is also a plus, giving operators their choice on how they want to use the 3rd channel. The light is more complex in switching operation options so expect to dedicate a couple sets of batteries to really get it down under duress. I tell folks to play with it constantly like you do with your television remote….
