Hi all... first post (after a long time reading and enjoying!)
My EDC is currently a (beloved) 2C Mag, with a (modified) regulated Diamond 1 watt. I've modded the brass lampholder tube by drilling and tapping a new hole for the focussing wheel a few mm's lower, as the Diamond wouldn't quite go low enough in the reflector to get a really tight beam (it does now!!).
I've also upgraded the Luxeon emitter to an RY0J, and it also has (modded!) lightweight plastic adapters in it so it usually runs on lithium AAs (or can take a single CR123 in the top adapter, regular AAs/Cs, NiMh, etc., etc...). Lightweight, great runtime, and fantastic throw with the Luxeon being slightly overdriven at about 360-390mA.
I'm thinking about upgrading it to a 3 watt Luxeon (with PWM dimming control), but I'm wondering if it's worth it? Will it throw that much further? Especially as at full power it will be drawing over twice as much current as it does now...
More light is always fun (!), but runtime and versatility in what cells it'll take is a big factor, too...
Any thoughts?
Cheers!
Any thoughts?
Cheers!
