Sundance has the following light available on their website:
http://www.sundancecatalog.com/shop...7731&itemType=PRODUCT&AS=1&keyword=flashlight
Leather-clad Flashlight
A classic since 1917, our tried-and-true flashlight will brighten his path. We wrapped it in chocolate top-grain leather, exposing the chrome plated tip, tail and thumb switch. Two-way switch. Uses three D batteries (not included). 3-1/2"DIA. x 9-1/2"L.
They even explain where chrome plating originated:
In 1913, English metallurgist Harry Brearly, working on a project to improve rifle barrels, accidentally discovered that adding chromium to low carbon steel gives it stain resistance. In addition to iron, carbon, and chromium, modern stainless steel may also contain other elements that enhance the corrosion resistance of it. It is the addition of a minimum of 12% chromium to the steel that makes it resist rust, or stain 'less' than other types of steel. The chromium in the steel combines with oxygen in the atmosphere to form a thin, invisible layer of chrome-containing oxide, called the passive film. The sizes of chromium atoms and their oxides are similar, so they pack neatly together on the surface of the metal, forming a stable layer only a few atoms thick that is remarkable strong.
I really like the look of the light, but know I would not be happy with its beam - so if anyone decides to mod more than one, I would buy the other.....
Thanks,
Marc
Thanks,
Marc
