bruner
Hi Everyone,
This is only my third or fourth post, so I hope not to come off too big-headed with this. I actually found you guys/girls when I was on Google trying to see if anyone was selling these things. If I would have found someone selling them, I probably would have bought one.
I have an idea for a new type of flashlight. I'm hoping that someone here might have the background and interest to try and build what I'm thinking about.
Here's the idea, I'll just put it out there and then try to explain it… CF (compact flash) type II socket flashlight peripheral.
In case you're not familiar with some of the terms I just used, I'll try to clarify. I have a pocket pc (PPC), it's a handheld computer similar to Palm Pilots, but running window mobile 2003. My particular PPC has two open memory slots on it, one for SD memory and one for CF memory. SD memory is small, about the size of a postage stamp. CF memory is larger, about the size and thickness of a pack of matches. There are several models of PPC's and Palm devices (which from this point on I will refer to as "handheld devices") that have CF memory slots. In my case, I have one SD card installed for extra memory, but the CF memory slot is open (and lonely)…
There are all sorts of peripheral devices out there that can be attached to a handheld device via the CF memory slot. I've seen barcode scanners, modems, magnetic strip readers, wifi adapters, bluetooth adapters, GPS receivers and even a TV tuner.
What I thought would be really cool is to make a CF flashlight peripheral which would be the same size and shape of a CF type II memory card. When placed in an open CF memory slot of a handheld device, the front edge would still remain exposed and could be lined with a handful of high output LED lights.
Aside from the task of building the CF flashlight, one would have to be able to write a program for the handheld device to control the light. There are several buttons on most handheld devices for things like address book, mail, phone numbers, etc… The CF flashlight program would have to allow you to re-assign one of those buttons to turn on the CF flashlight when the handheld itself is turned off. From that point, depending on how creative the programmer wants to get, I suppose you could have the program control things like brightness, colors, strobe rates or even patterns for the LED's to follow.
So, there it is. That was a mouthful... Any thoughts?
Thanks,
Dan
Thanks,
Dan
