js
As many of you already know, I own, or have had the priviledge of playing with, some really powerful and excellent big gun incandescent light, such as the SureFire M6, modded Tigerlights with Welch Allyn lamps and Carley relfectors, the 2200+ lumen 100 watt USL, and stock TigerLights, as well as more common incans, such as the SL-20X and MagCharger. And I've gone through some interesting changes in preferences with increasing experience.
At first, of course, I had the brightness disease. I wanted lumens, lots and lots of lumens. The more the better, throw and focus were of secondary importance. Total ouput and beam smoothness on a white wall were of primary importance. My favorite light for a long time was a Tiger85 with a heavy orange peel reflector--800 smooth, white lumens. Runtime only 17 minutes, and beam was mostly a flood. But man o man it was lots of light. And that's what I wanted. Next came the USL work I did with bwaites--a 100 watt axial filament in an OP reflector must top the list of beams with massive total output and pleasing white-wall shape!
But then something happened. The novelty of massive output wore-off, and as I continued to need my flashlights for daily use out in the fields and barn yard, I found myself drifting away from the sophomoric obsession with massive output, and back to reality where a 12 or 17 minute runtime is simply not very practical for most illumination needs.
And where did I end up but right back where I started this whole amazing hotwire journey: the stock TigerLight!
I can, and will in a future post, go on at length about why this light is so great and why I believe that it is simply one of the very best lights in its size class regardless of price, and why it is unquestionably the best large incan bang for the buck out there. For now, let me just hit the high points: this light has the highest quality components and build. The light has a hard anodized finish, gold plated connectors, sealed low-resistance switch, shock isolating gasket around the lamp assembly, direct connected components, NiMH battery pack, and halogen lamp with xenon fill gas.
More importantly, --and this is something that as flashaholics we all tend to forget or dismiss-- the OC TL is more than a light, it is a weapons system. What sets the TigerLight apart is the pepper spray capability, and the way in which that is implemented. A great deal of thought and design went into that. It was not some patched on component. From the ground up it was made to be a serious and useful force option tool for a law enforcement officer. Because despite what we flashaholics would like to think a bright flashlight beam all by itself is useless for self-defense. It may give you a few extra seconds to run away, but unless you have some force option to go with it, a bright light alone is shockingly inadequate as a self-defense tool. Even my landlord's benign dog is undeterred when facing 500 or even 800 lumens.
In any case I'm not an LEO and I'm not here to talk about the pepper spray part of the light. I prefer the shorter FBOP TL without pepper spray, myself, but I just didn't want people to forget what the TigerLight really is in its full OC TL incarnation: a weapons system.
So back to my story: I came full circle to the stock TigerLight and to an appreciation of the long runtime, small size, and long-throwing, bright white beam of the stock lamp assembly.
However, while all of the TL LA's put out the same beautiful white light and the same total lumens output, some are more tightly focused than others. The Gen1, for example, is the least tight of the TL LA's. And certainly, a wider beam has its uses, but I believe that for any given lamp and reflector combination, there is a "sweet spot" which yeilds the most useful beam for the same number of lumens.
I believe that TigerLight has absolutely NAILED that sweet spot with the Gen4 LA. Even with all of the options at my disposal, the Gen4 TL LA is one of my very favorite flashlight beams. This LA will throw like crazy. It will throw as far as any of the modded WA lights: Mag85, Mag11, Mag74, MC-1160. Whatever. Bring them on, because I have never seen throw like this from a 2 inch reflector.
Now, yes, quick aside, the MagCharger will throw as far as the TL Gen4 LA, but will only thow a pencil thin, laser-like beam out, which doesn't give you the contextual information you need in order to actually make sense of what you are seeing, or search and find someone. The reason is that the MC has a tight parabolic reflector with almost no degree of divergence off of parabolic. This is why de-focusing the beam any significant amount causes a hole in the center. And this is also why the beam has too many artifacts for my taste, no matter what the focus.
The TL reflector is also a fairly tight parabola, but this is combined with some divergence. Not as much as the SureFire orange peel reflectors have, but more than the MagCharger or Mag2D or 3D or etc. The result is a beam that throws very well, but is also relatively free of artifacts and which has a very nice amount of spill light to boot.
I find that the Gen4 TL LA is hands down one of the most useful beams I have ever experienced. When I was first out testing this LA, it was in rain and fog and cold, and I felt the exact same sense of command and capability as with MUCH more powerful lights, but with the wonderful security of knowing that I had a full 66+ minutes of runtime at my disposal. When shined out at distant objects, the light hitting the ground at my feet was just perfect for avoiding rocks and holes and other obstacles, and looking down did not temporarily blind me, as it would if I were using an 800 lumen 1185 based light. And while the beam doesn't look as pretty on a white wall as a SureFire M6 beam, for example, in use there are absolutely NO ARTIFACTS which impair illumination effectiveness.
Quite simply, this is one of the most useful and superlative beams out there, and it brings the TigerLight to near perfection, to the fullness of what it was meant to be.
And things get even better when you add the new premium battery pack to the package.
Now, don't get me wrong! If you have a TL already and you are happy with the throw of your current lamp assembly, then don't feel as if you have a second rate TigerLight. Not at all! You may even prefer the LA you already have for close up work around the house or indoors or for doing block searches, or what not. But if you appreciate a tight-beam and the best throw possbile, together with a big enough hot-spot for context and with a nice amount of spill light, then the Gen4 LA is for you.
They will be available very soon. I will post here with details when I have the appropriate info.
Again, as I mentioned in the thread on the premium battery pack, I want to say upfront that, yes, as a consultant for TigerLight I do get paid. I always try to be fair and unbaised and honest no matter what, and I feel that I am so in this situation. This is a really great light and a really great lamp assembly! But in case you have any doubts, I sent sample Gen4 LA's to SilverFox, bwaites, and Phaserburn, and they will be reporting on it as well. (As soon as they get a chance, of course). If you don't believe me, believe them. I will also be sending a complete TL equiped with a premium pack and Gen4 LA to Ginseng, but I don't have any packs at the moment, so that will happen a bit later.
OK! Thanks everyone!
