Just seen and bought at Costco (SF Bay area) today.
from the package:
24 LED
Rechargeable Work Light
H-intensity Illumination
Cool & Efficient Operation
Ergomonic Shape & Grip
Low Power Consumption
Long Working Life
Features:
12,000MCD Super Bright 24 LEDs
Anti-Impact ABS Housing
Anti-Impact Hi-Transparency Polycarbonate Lens
UL Listed AC 7.5V Adapter
12V DC Car Plug Adapter
Nylon Swivel Hook
ON/OFF Switch
3~4 Hours of Lighting after Each Recharge
Charging
Use only the supplied adapters for connecting this light to the power source.
Charging indicator will turn red to green when fully charged.
Charging time is 5~8 hours.
DO NOT leave the battery in a discharged state. Charge the battery once a month if the light is not in use.
Operation use the push button below the lens for ON & OFF mode.
To suspend the light, unclip the hanging hook situated at top rear of light, and hinge it upwards. The hook rotates 360° for multiple positioning.
(includes: light, AC adapter, DC adapter)
price: $19.99
The case is blue about 10"L*2.375"W*1.5"T in size. Plastic is smooth with a few ridges below the plastic clicky button. Basically like a cordless phone of a few years ago. Weighs maybe 6oz. The hook is might be a tad flimsy. Beam looks like a spot from 2' away but closeer up the spot is elongated by the rectangular LED array. Center spot is bright with a darker band and then a thin bright ring. Overall good construction but not fancy.
Seems like a great cool to the touch work light with no cord hassles. Price is good and light seems well made. Beam is uneven but should work fine. Some sort of built in stand would put this over the top.
Who wants to open one up and tell us what's inside and how to use the LEDs contained within!
Cheers
Geoff
from the package:
24 LED
Long Working Life
Features:
Nylon Swivel Hook
ON/OFF Switch
Charging
price: $19.99
Cheers
Geoff
