wquiles
No, I am not done, but I am way too excited about this accidental "discovery" - the HD45's awesome 45mm reflector fits almost perfectly inside a D M*g head. I bought one with the hope that if it did not fit at least some sort of adapter could be made. Little did I realized that it was a drop-in:
In this last picture you can see the light circle of contact with the inside, treaded part of the D head. Tip of pen points to the contact area:
On the bottom of the same contact ring, this inner rings does touch the top of the body when the head is screwed (you can almost see the grey contact area in this photo right underneat the pen's tip), so this determines the max as the reflector then starts putting presure on the lens. There is some small play, so without this contact with the body the reflector can actually more up and down some which of course can't be allowed - this play would have to be fixed for best focus. Perhaps some spacer, o-rings, shims, etc. - I am sure it can be fixed.
Now, as you can see above the reflector is "way" too long for a standard O-sink. This would be the real trick as the shoulder of the O-sink would have to go away and the whole O-sink would have to be seated far deeper in order to clear the bottom of the reflector. Instead of cutting the switch flush as normal for these types of mods, the top of the switch (after carefull measurements) could be cut to the "right" height so that the O-sink can actually rest on top of it - this would then determine the propper LED position
As I said, not done, but after some quick measurements and dry fitting I am 100% convinced that it can be done. Imagine that: your own poor-mans HD45 with "your" choise of converter, "your" LED of choise (3W or 5W), and whatever battery arrangement you can think off. The posibilities are endless once we can figure out how to use this awesome reflector in the M*g !!!
Will
Will
