The_LED_Museum said:If you remove the IR filter, please be damned sure you use safety goggles designed specifically to attenuate radiation at 808nm and 1,064nm!!! oo:
I believe the NIR laser diode inside is 500mW (0.5W) at 808nm - just outside the range of human vision.oldlaser said:Does anyone know the approximate power of the IR laser used in the 105?
The_LED_Museum said:I believe the NIR laser diode inside is 500mW (0.5W) at 808nm - just outside the range of human vision.
