They have been at my Walmart for a month... I started to pick one up when I first saw them, but I thought I'd see what CPF thought of themn first... Did a search then, but no hits....
Well, I decided to pick one up today, and then when I got home, fond not only this thread but another....
Well, anyway, here is my mini-review:
While the concept is neat, the execution IMHO leaves much to be desired. Here is what I found:
With one leg filled (3AAs) Lux readings @ 1 meter:
1 LED : 26 LUX
3 LED : 61 LUX
6 LED : 121 LUX
All three legs filled: (9AAs)
1 LED : 26 LUX
3 LED : 65 LUX
6 LED : 135 LUX
So, contrary to the blurb on the package, it is a little brighter with all the batteries with 3 & 6 LEDS, the 1 LED is the same.
Throw?
One LED / about 10-12 ft of useful brightness... Enough to get around the house in a blackout, or walk slowly through the woods. Three LEDs not much more throw, a little more brightness though.
With all 6 LEDS running maybe 30 ft of useful throw.
I don't even know how to describe the beam. I don't like it myself, but other people may.
Here are some beamshots: The light is one meter from a 20X30 inch white foam board with the dot grid on 2 inch squares, and the words RED GREEN BLUE written in those colors with a Sharpie felt pen of the appropriate color. The camera is about 1.5 meters from the target, with F stop 2.8 and exposure length 1/60th second for each shot. The images should be pretty close to reality, depending on your monitor settings. All done with a full 9 fresh AA alkaline cells operating.
The first shot is with one LED on:
The next is with three LEDs operating:
And this one is with all 6 LEDS on:
And this one, the light is about one foot away from the target to show the kind of weird beam pattern, with six LEDs operating:
As you can see there are a lot of artifacts that may or may not be distracting to you.
As a worklight, ... say for wrenching on your car, the the 3 LED setting is barely, barely adequate for non-detail work. 6 LEDS almost adequate, but leaves much to be desired. My Petzl Myo 5 headlamp with the 5 LED beam is better.
It isn't a positive mechanical latch that holds the tripod legs in when you are using it as a handheld. Just a couple of small magnets,,, and they don't hold very securely. the "open" button just slides the little rod that the magnets are on out away from the little steel buttons on the tripod legs. All in all, that setup is a waste of materials and manufacturing steps IMO. Coulda just used solid mounted magnets if that is the way they wanted to go... I suppose a mechanical latch would have either had to been more bulky or would have been to delicate for extensive use. so I don't know which would be preferable in the long run.
In the hand, it feels like holding a M*G 3D, except a little softer grip due to the rubber center. Length is about an inch shorter then the 3D, so, about halfway between the 3D and the 2 D.
The lens/optical assembly is held on with a rubber? bezel and three small TORX screws. I think a #4... This may be important, as this light is just begging for a modification. I'm not sure what LEDs are in it, but the new 18,000 MCD Nichias should be one way to improve it....
I just opened up the head... Man, there is a lot of electronics in there.... Considering the battery configuration, I don't see the point. Ten transistors two ICs and assorted capacitors and resistors. wow.
I took some photos of the electronics.. but I have to crop them down a bit before posting... Probably be able to post them in a little while.
