Hi, I've just been through this dilema for my 6P and for what you say you want it for, the L5 Head I personally think will be too much power when not needed, plus your batteries won't last near as long. I recommend the new style KL3 Generation 2 head as you can get it in black HAIII finish and it really beats the heck out of the bugout gear 3 watt. Battery life is about 4.5 hours plus on full power then decreasing thereafter. To put it simply, I've had the original KL3, then the bog 3 watt, then the new improved kl3 and WHAT AN IMPROVEMENT.
It all depends on what YOU want as no one knows better than you what will make you happy. If you want economy, then go with bug out gear 3 watt, (the 5 watt is too hot for the 6p) but you don't have the quality. However, if you want the quality then you can get the new improved KL3, black HAIII for under $60.00 and it does blow away the bug out gear drop in. Also you can go with the KL5, but that will cost lots more, and I think is an overkill for the 6P.
If you check with lighthound, or john at
www.lighthound.com he can get you one. I had to wait for a little while for mine, as he was out of them, but it didn't take too long, and it was worth the wait.
