Justintoxicated
Ok so I'm using an LM317T to controll the current to some Red Star-O's
I'm trying to figure out an easy and cheap way to vary the brightness when I activate a switch.
I'm thinking there should be an easy way to do this with a relay but I don't have ay experience with them.
Basicaly I have 12V Always going to the lights, when I hit a particular switch a seperate 12V line becomes available. (I want the lights to get brighter when I activate this switch)
Is there a way I can vary the resistance (add more resistors in parallel) going to the LM317T with a relay wired to the switch?
If not, is there a way I can switch from driving them with one LM317T to another LM317T with higher current output through a relay?
Probably a dumb question but I have not yet needed a relay for anythign so I don't know. If Possible part numbers from ratshack would be awesome! Smaller the relay the better!
