AFAustin said:
Would any CPFers familiar with them please post some comments about the various Premierlight models? I've searched around and haven't come up with much. I've heard they're built like tanks, and some of the models have nice features, like multi-level output, a laser in the center, etc.
Greenmountainelectronics seems to be the biggest vendor on ebay, and I've seen a few online dealers. Would also appreciate any ideas on best and cheapest place to buy.
Thanks.
I have the PL-5, PL-7 (with laser), and PL-10 models.
PL-5: two level light with SOS. Light outputs are relatively dim with a very small hotspot in the center. Unfortunately the beam is not smooth; it is SEVERELY artifacted with weak light and dark rings and other dark spots. This light has by far the worst artifacts I've ever seen!
Enough output to light up small rooms and up to about 10~15 yards.
However, due to weakish light output and artifacts, this light is NOT recommended!
PL-7: Red laser pointer puts out good beam in excess of 200 yards. Six white LEDs output good beam with slight dark area.
White light output is sufficient for rooms, and perhaps up to ~30 yards otherwise.
PL-10: three level light with SOS. Light outputs are good, with good beam, although there is slight dark area to the lower left of the beam. Beam is far smoother than the PL-5. Three LEDs are used for low output, then five LEDs for mid output, and finally all seven LEDs are used for high output.
Outputs are good enough to light up rooms easily, and up to around 50+ yards otherwise.
Sorry, no digital camera, otherwise I would have included shots of respective light beams!
I have purchased thru Green Mountain Electronics on several occassions; as their prices are usually very good. However, their shipping has (recently) become quite slow. So you
may have to wait several weeks before orders are shipped!
Hope this helps!
