zachtos
- Joined
- Nov 15, 2005
- Messages
- 6
I have a challenge for the LED modders here. I have been researching LED's for over a year and want to start a fairly costly project for a small coral reef tank. If it is successful and cost effective it will be scaled up and picked up by our Reef Tank community. I want to avoid wasting time/money so I am asking for help in advance. Here are my specifications:
mounted in 2.5 gallon aquarium hood
6"x8" circuit board
will use current limitting resistors
capacitors to smooth voltage and for light fading effect (sunrise/sunset)
small PC fan for cooling
runtime 10 hours/day
LED's to be 10,000K temp range
desired spectral peaks at 420nm, 460nm, 550nm
ideas:
125 - 10mm ultraBright 80,000 mcd -- rated at 20mA, 3.3V typical - powered by dual 1A 16 VDC wall transformers
or 8 - 3W luxeons (heat would be a big issue though with these)
Goal:
pack as much focused light in this area as possible
heat to a minimum
cost under $200
Any suggestions/potential issues you see?
6"x8" circuit board
ideas:
Goal:
heat to a minimum
cost under $200
