Guys, he
asked for an electric drip machine!. If you are going to go OT on recommendations, at least try to first give some on-topic ones first.
chmsam has some good points in his post above, but I would add a few points:
Water temperature is also key, and most electrics don't heat the water up hot enough.
Also, those that keep the hot water in a reservoir are to be avoided because the water looses all of its oxygen and the coffee tastes a bit flat compared to methods where you heat and infuse over a short time period.
Anyway, back to the topic. Most important point here is this:
spending a lot of money on a coffee maker is no guarantee that it is good. One of the worst makers I have ever experienced was a very expensive, "high-end" brand with thermal carafe (which I think is a waste).
Check out the consumer reviews on
www.coffeegeek.com to see how perspective coffee makers rate.
I would personally recommend going on ebay or doing a websearch for a new-in-box KitchenAid 4, 10, or 12 cup electric. They are making a really expensive one now, but it has a reservoir and is just not worth it. The ones I am talking about should be $20 or $30 or $40 or so, but not more. And they are great. I have the 4 cup ultra and it makes a pot in the right amount of time (4 minutes) and at about the right temperature, although it is, admittedly, a bit low--but pretty good for an electric.
If you want to spend more money, a technivorm (sp?) is certified to make coffee at the right temperature, but some of the reviews put me off a bit--you'll see why if you read up on them.
On to press-pots and vac pots:
These DO NOT, categorically, make "better" coffee. Saying that is like saying that gold filters "make better coffee than paper filters". Not necessarily. Not if you like a very clean, sediment-free, cup of coffee. Be careful before investing in a press-pot or vac pot. And if you DO go that route, you will most definitely need to spend a LOT of money on a good grinder. Otherwise you will most likely be disappointed.
In fact, getting a good grinder is a very wise coffee investment, . . . if (and only if) you are looking to start exploring the world of fine coffee. If not, get a cheap (but good) electric, use paper filters, and get any blade grinder and whole bean coffee which you keep in an air tight container, and NOT IN THE FRIDGE.
Empath, please note the things I didn't say. I am being good. And note that Trashman is not associated with me, LEDmodMan, or Javafool. I mean, we are not colluding here.
For those who are interested in learning about, or talking about coffee and beans and *cough* roasting your own, please refer to, and confine all discussion to, LEDmodMan's thread
A Coffee thread for the Café...
