Recommend a flashlight checklist:
Short Essay Question: What do you intend to use this light for?
LIGHT WILL BE USED AS TACTICAL LIGHT. I CARRY A HANDGUN CONCEALED AND WOULD LIKE A GOOD LIGHT FOR LOW LIGHT SITUATIONS.
1) Price Range: This is usually the easiest question, but be prepared to change your mind when you are done answering the rest of the questions!
____$1-10
____$15-30
__X__$40-60
____No Limit
2) Format:
__X__Flashlight
____Headlamp
____Portable Spotlight
____Lantern
3) Length:
____1-2 inches (Keychain sized)
__X__2-4 inches ("Pocket carry")
____4-9 inches ("Holster carry")
____I don't care
4) Width
__X__Narrow
____Wide
____I don't care
5) What batteries do you want to use? Common size alkaline batteries are easier to find and less expensive but don't pack as much stored energy and can be severely impacted by cold temperatures. Lithium batteries have long shelf life (10+ years) and are not nearly as affected by cold but must be kept dry and are usually much more expensive.
____I want a rechargable system (generally the best for everyday use)
__X__I want common Alkaline batteries (AA, AAA, C, D)
__X__I want lithium based batteries (coin cells, CR123, etc)
6) How much light do you need? Sometimes you can have too much light (reading a map or book close up with a 100 lumen light is impossible).
____I need to read a map or find a light switch in a dark room (5-10 lumens)
____I need to walk around a generally paved area (15-20 lumens)
__X__I need to walk unpaved trails (40 lumens)
__X__I need to do Caving or Search & Rescue operations (60+ lumens)
____I need to light up an entire campground or field (100+ lumens)
7) Throw vs Flood: do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an "X" on the line below.
Throw (distance)--------------------XXX----------------------Flood/closeup
8) Runtime: Some manufacturers severely overinflate their runtime claims (especially with LED lights). I am discussing usable runtime measured down to 50% from first activation with fresh batteries.
__X__20 min (I need a very bright light for brief periods)
__X__60-240 min (1-2 hours)
____240-360 min (4-6 hours)
____360+ min (More than 6 hours)
9) Durability: Generally the old phrase "you get what you pay for" is very accurate for flashlights.
____Not Important (A "nightstand" light)
____Slightly Important (walks around the neighborhood)
____Very Important (Camping, Backpacking, Car Glovebox)
__X__Critical (Police, Fire/Rescue, SAR, survival)
8) Switch Location/Type: Circle all that apply.
Sliding Switch |X Momentary Switch X | "Clickie" Switch | Remote Control
Body (Side) Switch |X Endcap Switch X| Rotating Head | Rotating Tail
I don't care
9) Operational Modes: Check all that apply.
__X__A simple On-Off is fine for me
____2 light levels (High power/short runtime and Low power/long runtime)
____Multiple light levels (some lights have 5-16 variable light levels)
____Strobe mode (blinks to show location)
____Tactical Strobe (Flashes rapidly to disorient an opponent)
10) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
• Red (night vision preserving) filter(s)
• Other filter colors (Amber, Green, Blue, Etc)
• Built-in second (or spare) lamp or filament
• "Hybrid" light (combines Bright Incandescent and long running LEDs)
• Belt clip XXXXX
• Holster
• Wrist/Neck Lanyard
• Waterproof – (how deep?) xxxxxxxxxxx (rain proof)
• Non-reflective/ dark finish (stealthy/ hard to find) vs. bright for easy locating? XXXXXXx
• Corrosion resistant or hard-anodized finish? XXXXX
• Kobuton/self defense features?
• Non-sparking Intrinsically Safe (IS) for use in explosive environments?
____$1-10
____$15-30
__X__$40-60
____No Limit
2) Format:
__X__Flashlight
____Headlamp
____Lantern
3) Length:
____I don't care
4) Width
__X__Narrow
____Wide
____I don't care
I don't care
• Belt clip XXXXX
• Holster
