Kiessling said:
... almost.
There's still the heat that makes me worry ... at 1000mA to a LuxV there's quite a lot of it ... and availability of those isn't that great either!
bernie
In my own personal experience, yes, heat is a problem, but mostly with the shock-isolated bezels as the "poor" module has no way to get the heat to the body and your hand. I have a WX1T on a DB1000 and I was getting the module to get very hot with almost no heat to the KT4 head. I was not until I used some thermal AA in the negative contact spring and in the matching body section that I was able to finally get some of this heat to be "passed" on to the body.
I don't own a non-shock-isolated bezel, but if the reflector is in direct contact with the metal head (instead of floating, and not touching anything as in the shock-isolated bezels), then the situation should be better
On my M6 (with a KT4, shock-isolated bezel), I had to re-aply some of the thermal paste to get heat transfer to the M6's body. The only bad thing is that then you change to a "normal" incandecent lamp you do have to clean the body of the host so that you don't get the thermal paste on everything!
Will
