My LongBow Micra mod. with Lux III TXOJ und Wizzard II/950mA in a McCapsule modul used 1,7A with a R123.
So i looked for a way to use this modul with a 18650 Li-Ion.
I found the Police/Walther flashlight.In this flashlight is the bulb in a Alu base with external thread.
So i boring the body to 18,5mm and made a new thread for the McCapsule modul. With this modul you need the small ring for minus contact,but not with the original modul.
The moduls are a little longer than the the Alu base, so you must shortening the tail switch inside part to make sure to get contact.
