Robocop
Moderator, *Mammoth Killer*
I was playing around with a cut down MJ and this little 5mm will make a great spot and spill light using a reflector. I read that the cut down versions are made to act like side emitters and I began reading up on side emitters in 1 and 3 watt versions.
My question is why are the side emitter luxeons not ever seen in any higher power lights with a reflector? I would think that the higher power ones would really do well with a reflector if the little 5 mm ones do such a nice job.
Any one ever try any luxeon side emitters with maybe a 20mm reflector? Just curious why they are never really seen or even talked about much.??
I tried a search however could not get it to work using Luxeon+side emitter as a keyword.
Thanks....
Thanks....
