HighLight,
You have a few rechargeable options:
If you want to work with the stock lamp (P60) that came with your G2, then SF's rechargeable option requires that you purchase an AN19 cell extender and their NiCad battery and charger.
If you want to use one li-ion battery such as the 168s (17670) then you will need to purchase a Pila 3.7 volt lamp (they are the same shape as the P60) and I think will get about 45 minutes runtime.
If you want to use 2x R123, then as falconz said, you will need to use a P90 lamp and you will get about 25 minutes runtime. If you want longer runtime, you will need to purchase an A19 cell extender (or and AN19 and a spacer) and could use 150s (17500) cells for about 50 minutes runtime.
If you want to go LED, G&P makes 1watt, 3watt modules that will run on just about any battery configuration you can fit in your G2.
Hopefully one of these options will suit your needs.
