I guess its the older version where the focus is adjustable.
The Constant-On does not work perfectly anymore, although the Momentary-On never fail to work. What happened was that when the tail was rotated into "Constant-On" the light would either:
i. not turn on at all
ii. turns on and but turns off by itself immediately
iii. turns on and dims significantly
Sometimes it works as it should but most oftenly the problems sets in when the tailcap was unscrewed and put on again, eg. after a battery change, I had to remove the tailcap and replaced it several times to get it to work properly, only to fail again after sometime. I suspect there must be some connection problems within the tailcap, rather obvious it seems.
The Lamp Assembly was properly and tightly screwed in.
Any idea how to fix it? Thanx in advance.
