Robocop
Moderator, *Mammoth Killer*
My friend and fellow member Owen gave me an old sandwich from the Shoppe and I have put it to good use. I do not know the BIN nor the output however it made a good mod for my X1.
I opened the X1 with the freeze method and cut vertical slits in the bezel to spread it out a little for re-assembly. I now cut off a little from the X1 making it much shorter and bored the bezel end using a Dremel tool. I used the reflector from a RiverRock 2-AAA light and put it inside the bezel with an o-ring and lens. You can spread out the little cut slits to help hold the reflector and to also make the bezel fit more tight when re-assembled.
Next I soldered a casing around the top of the sandwich that came from an old Dorcy AA 3-LED circuit. It was an empty casing that held the old Dorcy circuit and fit the sandwich like a sleeve. This does 2 things in that it makes the sides of the sandwich act as a ground and it also helps transfer heat to the X1 body.
Next simply slide it all back together and it works very well all in a package smaller than my Fenix and a little brighter. I have to use a 3 volt lithium in AA size so the comparison beam shot is not really fair when compared to my Fenix. I imagine a rechargeable 3.7 volt AA would also do well in this light. It will run from a lithium AA or even an alkaline however it is not nearly as bright.
Regardless it was fun to make and it works very well.
Enjoy the pics and the beam shot is the X1 on the right and my Fenix on the left from about 8 inches to the wall.
