luigi
Let's say you have a flashlight and some paper sheets, if you cover the light with "n" sheets then you will see a spot in the top sheet, you can keep doing this until no spot at all is noticeable in the top sheet. Is the number of sheets of paper that you need a measure of anything? Because -don't ask why- I was doing this experiment and found some puzzling results.
Luigi
Luigi
