I am helping my parents prepare for having their bathroom re-decorated.
Today I was in the loft (attic) with the upstairs lighting switched off at the fuse box so I could disconnect the power shower, two lights etc so the bathroom could be gutted for the new tiling work being started Monday morning.
Anyway, my EOS was great - light-weight, powerful and compact. It was also cold compared to using an incandescent that would have heated up the small crawl space I somehow managed to worm into to access the wiring.
I also had to disconnect two radiators, remove the basin unit, and the shower (yes, I want a gold star ). Towards the end the day I was removing misc silicon-type sealant from around the bath and using the EOS because there was no other light because some idiot had disconnected all the lights
The beam does not blend from spot to surround - there is a "halo" void which is a bit annoying sometimes. Additionally, it's not as bright as I needed for some tasks. The runtime is excellent though so I guess that's the compromise.
When it came to cleaning the walls with a misc white spirit type liquid I needed a flood light. The SureFire 10X did the job but the heat from the beam was obvious.
One of the cool things about the EOS is that I'm quite happy using it hand-held for shining in the tight spaces around the bath and under the floorboards etc.
I was impressed enough at SS2005 to purchase one at the show. I've used it a lot and my brother has been borrowing it for night-hikes and camping.
I think I'll pick up some more.
Strangely it doesn't have "EOS" on it but it is an EOS based on the photos and specs that I've seen. I purchased it from the Princeton Tec booth... I see it comes in orange. I'll seek out orange versions. Sometimes kit is important to be seen and located.
Al
