JimmyB
Not sure if this has been posted before. For those that don't use the pocket clip on their HDS flashlight but don't like the bare holes or screw heads sticking out, there are a variety of solutions. The one I use is a couple of set screws. They fit flush with the holes, look more finished, and are easy to remove if you want to use the clip. 4x40 3/16 are about the perfect size although you have to tighten them down fairly hard to get them flush. I use a 1/8 instead and a little dab of blue (242) Loctite. A .050 Allen wrench fits the head. I like the look much better than the holes staring me down. By the way, this size is pretty small so not everyone will have them. Lowes only had #6. To get 4's I had to go to Tacoma Screw here in Seattle. In any case you may have to get them from a specialty fastener place. Later...
JimmyB
JimmyB
