12v red/white switchable interior lights?
Bravo30
[FONT=&quot]I have my Van lighting set up so that there's 2 lights directly behind the front seats wired to their own switch next to the sliding door so I can operate it while I'm inside or outside of the van. Anyway, I use these lights a lot but I need something more discrete for when we're around other people in a parking lot or something. Ideally I'd like to have a pair of lights that switch back an forth between red/white that way I could use the existing wiring and holes.[/FONT]
[FONT=&quot]any decent lights come to mind?[/FONT]
Alaric Darconville
Stillwater, America
You can also just insert red LEDs and pull some more wire and replace the SPST switch to a DPDT switch, maybe then have up as white, center off, down as red. Then just have the red LEDs in with the white LEDs you already have if you don't want to change the lamp assemblies (since you said you already had lights installed).
