You just wait until I get my Cree Q4s and Q5s in those P3Ds - then you'll see 160 out the front.Spypro,
I know you like the Wolf-Eyes and P3D for their 170 lumens and 160 lumens claims, respectively. But keep in mind those are emitter lumens. the Wolf-Eyes is likely around 125-130 lumens out the front, and the P3D tested at 125 lumens from FLR. Just wanted to note this to you so you are comparing apples to apples.
Hi Guys,I really like the DefenderII with is nice looking bezel.
I'll contact PTS for more informations.
Hi Dinan,Thanks for the details!
I'm still a bit confused about the run times though.
I was under the impression that the 18650 unregulated would give a longer run time than just 30 minutes...
(Using the Lumapower M1 as a reference: http://www.flashlightreviews.com/reviews/lumapower_m1.htm)
I'm a flashlight newbie so I have no idea
Hi Dinan,
The Graph on Flashlight Reviews indicates that the Lumapower is not regulated and starts to dim from the beginning while the Wolf Eyes is fully regulated and stays the same brightness during the regulation period. Once the voltage from the LRB168A/18650 battery falls below the required amount the lamp goes into a non regulated mode (like the Lumapower's entire battery life) and gives diminishing useful light until the battery shuts it's self down at the low voltage cut off. With full regulation you get the maximum amount of light and Wolf Eyes designed it to fall out of regulation with useful diminishing light so you know when your light needs a charge or new batteries.
Yep ! I'll do that.
Before I want to see Mike's answers to my questions
EDIT:
I have updated my questions list:
Can I use the CH-02 charger to charge other battery than the LRB168A ?
Is there two stages of output ?
Is the 3.7-13v module can take the LRB168A and 18650 ?
What is the runtime with 18650 battery ?
What is the runtime for the low and high mode ? (if there is two stages)
If you are only running the 1 x 18650 then you are better off to buy the 3.7-6V LA (which is the LA that comes with the Defender II), as i understand it the 3.7-13V LA is not regulated with a single 18650.
I have the 3.7 - 13V myself because these lamps are not cheap and I want the versatility to be able to use it in my Sniper and Defender II, 3.7V 18650, as well as my 9V Raider 2x 18500, or my 9V Leefbody 2x 18650 lights. I have this lamp in my Sniper as I write this and have been using it for a couple of weeks now as my home light and have no issues with regulation.
I stand corrected, must admit i was only going off what i had read, not personal experience. I do agree they offer a wider range of opportunities, but i wonder why there is the 3.7-6V and the 3.7-13V available if there is no benefit with the 3.7-6V.
Spypro, the run times quoted are with a 18650 which is the same as the WE LRB168. I thought i read somewhere that the 168 has a slightly higher capacity than the AW, but both of my cells are labelled with 2200mAh so i am not so sure........anyone???
I have found that because the AW 18650 does not have protruding terminals it seems to have problems with activating high power in the Defender II, a magnet rectifies this but obviously isn't ideal. Not sure about the LG, but the WE works perfectly which since it is made by WE you would expect.
If you buy the Defender II then i believe the package comes with a rechargeable plus a charger included in the price. I have read that PTS will not be offering this light, so you might have to talk to Glen from www.quarterflash.com.au
