1940's Burgess Range Finder
bykfixer
Dust in the Wind
Mr. Postman dropped off another jewel in the rough today. A 3 cell Burgess Range Finder to be exact.
It's a chrome body light that is light as a feather while feeling substantial enough to evoke a sense of stability. It is in great shape on the outside with very little scratching, no dents and no rust. The guts are loaded with tarnish which is typical for anything this old. There is lots of copper and brass for added weight, but durability.
It was a pleasure turning it on and nothing...until a whack to the palm made it spring to life.
Yessssss!!!
No flicker what-so-ever.
Aiming at a wall, not for some purist reasons but just for kix & giggles. It was a blast to see what happened next.
That nice under driven incan yellow feathury edges raised a smile on my face after a weird day at the office.
This is a civilian light that wouldv'e likely used by campers, hunters and folks who preferred well constructed flashlights at some point between WW I and II.
It'll have cells in it and be left near my back door for occasional use.
It's my first light made by the CF Burgess company but after spending 10 minutes checking over all those little things I figure there'll be more along the way.
Now the details:
It's a dual switch light where one is for on/off and the other slides the lamp forward. Unlike many lights from the days of yore, this one has a lamp assembly attached to the body and not the reflector.
A fairly ineffective approach in todays world but probably seen as an idea with ground breaking potential...(can you say Maglite?)
The assembly slides back n forth along a pair of keepers.
It's pulled in all the way in this pic.
All the way out in this one.
Note the vertical brass keeper to the right vs a horizontal plate.
Basically what it does is change the size of the spot from pencil to wider.
Beam pulled all the way in.
Midway. Note the spot is wider.
This was my favorite.
All the way forward.
The supplied 4.5 volt 2.5 watt bulb is not very bright. Maybe 25 lumens is thrown forward of a brass reflector.
Check out how thick that lens is.
It protrudes forward of the anti-roll bezel, which lends to the spill. At the same time creating a nice ring around the edge.
The tailcap is a brass number with a copper spring and a nail hook.
The hook protruding to the side here.
One of the things I noticed was how smooth the threads are on this one. On other old lights it's an excersize in frustration to get threads started, but in this light it was a breeze to remove and replace items at both ends.
The ribbed steel shows there was a leaker at one time. My guess is it was found by the eBay seller with ancient cells.
At some point I'll clean up the light inside and out so no palm whack is required to make it light all nice n consistant.
Here it is next to a Mag 2D and an old cracker tin from my youth.
Minimoog
Oh that is nice. That style of protruding glass was popular in the 1920's and 30's and I do like it. If you can find one, a halogen bulb will work really nicely- especially with rechargeable cells. I agree about the threads - so easy to start and turn.
bykfixer
Dust in the Wind
Thanks for the tip. If this thing can toss out 75-100 lumens via that shiney brass lens that would thrill me a lot.
I wondered about adding more output, but did not want to cook the innerds via too much amperage. (Or heat)
But did contemplate a pair of gentle 18650's (in a pvc sleeve) and a 6 volt bulb.
But as you know some bulbs are becoming like hens teeth.
Minimoog
If you look on Reflectalite website, there are quite a few nice Halogen bulbs in this fitting - I have used the 10 Watt one in a vintage torch and it really sings - I used Eneloop Pro AA batteries in a 3AA to D adaptor.
jrmcferren
Waynesboro, Pa FM19es
After a quick browsing of bulbs, I found that this likely used a #13 lamp which has the proper voltage rating (4.5 to 4.9 is usually used in 4 cell lights). The largest disadvantage of the #13 lamp other than being dim is that with modern Alkaline cells you run into a runtime limitation not from the battery life, but from the lamp life (approx 40 hours battery vs 15 hours lamp). The advantages of staying with the 4.5 volt lamp include longer lamp life, but at the cost of intensity (you won't have 4.5 volts for very long) and battery life (more miliamps).
bykfixer
Dust in the Wind
Bulbs for bicycle lights...
Byfixer likes!!
Thanks for the tips fellas. Shows me I have a lot to learn.
It appears 10w e10 type halogens won't be easy to find on this side of the pond Mr. Moog.
So, I may try a #157 (6w) thanks to the link by Mr. McFerren.
A proper whack to my palm today seemed to bring out a tad bit more candles. Took it out for a walk and it made a fine 35-50' light under a moonlit sky.
And although I don't ordinarily stare at flashlight beams on the ceiling, this one has character.
With a slight slide forward or backward of the lamp the character changes too. It's kinda like laying in a field as a lad, chewing a long grass stem and watching the shapes of clouds.
And I absolutely love the ring.
Last night when we turned the lights out for the evening retirement, I used the flashlight to traverse down the hallway by the incan glow. That ring cast a light on nearby walls that evoked a sense of aisle lighting in a movie theater... it added even more character to the beam during our short jaunt.
Edit:
I went the sterile route for walking with this one...
Bought 5.
An 80 lumen LED 'bulb'. WTH? Right? Preseve those #13's on the way is what I'm thinking.
LED...boooooo!!!
So I bought a 2D Ranger for those things and a pair of LifePo 18500's.
