Open up the opening at the head end of the body just enough for the smaller part of the module to slide through then drop the module in from the battery opening and see if it lights. The 3D module is longer than a MM sandwich so you'll have to figure out how to get the reflector in there. Also, you'll need to get a tail cap switch as there will be no way to turn it off once the tail cap is installed.
