7800lm 4xCREE XML L2 LED Flashlight Torch ebay (to replace a L&M SOLA 4000)
super kermit
I have just bought an ebay dive light to go with my GoPro.
*link removed
Some quick Qs.
I only have protected 18650 batts;
*link removed
and
*link removed
and feel safer with protected batts.
Charger is
Nitecore I4 V1 Li-ion Ni-MH Ni-Cd Smart Battery Charger4-channel charger / version 1
*link removed
to be replaced by
*link removed
Nitecore I4 V2 Li-ion Ni-MH Ni-Cd Smart Battery Charger4-channel charger / version 2.0
I will be using 18650 to 26550 adaptors for now.
Has anyone used the above light?
What SAFE 26650 batts can I buy?
Price is NOT an issue for the batteries.
I need the best quality.
Packhorse
New Zealand
With links removed its a bit hard to see what you are talking about but I think I found it.
What is it you want to do with it and your Go Pro? If you expect it to work as a video light you may be a little ( a lot) disappointed.
Quality 26650's can be a little hard to come by. If all else fails the Panasonic 3400mah 18650's may be a good substitute.
Greta
Arizona
Am I not able to post links?
Can I mention the bran/model etc?
Your post was so heavy with external links, it looked like a billboard for at least a half dozen companies. Your post could have easily been posted without the links while accomplishing the same goal. (I did check that out before editing).
super kermit
I can understand.
Can I put the links or only the make and model number back in?
super kermit
Yes, as a cheap video light for the GoPro Black 3+.
The Sola 4000 is expensive and I have already lost 2.
So I am looking for a cheaper alternative.
