You'll probably get a cleaner beam with the Black Flat as opposed to the XPG2, because the Black Flat is factory dedomed and the XPG2 is sliced from Vinh. Getting perfectly clean dedomes is an art in of itself.
Being so tiny though, it will never be easy to center and tune for the Black Flat.
I recently got the black flat Olson version. I own no other T21vn version.
I can say this for the flat black, it is called flat not because of a dedome, but much more wonderfully, this LED is produced FROM the LED factory without a dome, making the lack of dome absolutely flat, which has lots of automotive lighting purposes, while posing as a ridiculous thrower for flashlights. This factory-flat LED is extremely intense also because of it's size, even moonlight mode is too much for my eyes and will cause dots even if looked into at full daylight hours. I can say my version seems to have no abnormalities in the corona and a perfectly centered LED. Critical for the beautiful hotspot it has.
Although aware of the following before purchase, there are too problems I didn't anticipate from such a narrow beam, the beam is very narrow, with a tight hotspot of minimum range of 100 meters (the spill is wide enough to walk around with) > ; the unknown was; 1) the spot jiggles around like binoculars and is tough to keep centered on a target, and ; 2) I rarely use the turbo thus, maybe, the normal version with twice the lumens and half the intensity makes more sense for most people/situations.
But, I stand by that for me, and hobby purchases, this is an incredible light.
