What a great job in craftsmanship and talent! Your universal P-60 headlamp looks very promising. I would be interested in a final product.
What I'd like to see is a better mounting system (hopefully possible) where the butt of the head meets the back plate of the headband. For now it looks like it sits bit high and might be uncomfortable to wear for prolonged time? How does the prototype feel when you wear it?
For a battery system, I think, nothing can beat a simple aluminum tube design which is easier to produce and waterproof. An option to carry 17670, 18650 and CR123s will cover most people's battery preferences. A single 1x version and a 2x 18650 for those that want 2x batteries. The battery tube can connect with quality coil wire with a disconnect. The battery tube pack could mount on the back to counter balance the P60 head.
Good luck on your project. Look forward to see the final result.
I got away from that style of mount for a couple reasons.
P60s are long, with the length needed and a pivoting bracket, it would stick out quite a ways, and would be prone to a lot of shaking while walking running, etc.
Also, with the light so long and close to the eyes, you get a "baseball cap" effect. You cannot see things directy above and ahead of you. This can be a dangerous problem in certain situations.
It can also make it very easy to temporarily blind yourself when anything gets near your eyes, if the light is very close to them.
I have worn this protype for probably 15 hours total so far. With several 2 -3 hour sessions. It is comfortable, doesn't shake around much at all while running, and it's pretty easy to forget that you are wearing it.
I do agree on the battery tube idea. I have a couple 1x and 2x 18650 tubes made up. They work well. I will try to work on them some more soon.
I am unsure of the wire type to go with. I like the coiled wire idea, but am unsure if that would be best, because it would be bulky if run under clothing. Maybe a short coil from the body, that has a disconnect that can be plugged into the battery pack on the head (like you said) or also it could plug into a straight wire running to a hip/belt battery pack.
Thanks for the input, and please, anyone keep it coming.
